Dionex ICS 2000 Eluent Bottle Cracked
Hi, anyone worked with ICS 2000? Went back to work one morning, eluent bottle cracked/leaked and water all over the top heap of IC cpu. We've been having problem with the pressure pump head leaking and we kept on changing piston seal and o rings for almost every week. Pressure reading was 1900+ usually and on that day went up to 2400.
Anyone has an idea how to solve the problem? Thanks in advance. :)
Do you mean the 2-L bottle (usually for water) or do you mean the eluent generator block? I've had that crack.
Users browsing this forum: Google [Bot] and 1 guest
