problem with vitamin A analysis
i am working on the HPLC analysis of fat soluble anti oxidant vitamins (Vit A and E) in biological samples. during working on serum sample i found an extra peak preceding the vitamin A peak. I am not sure abt the nature of that peak so please help me in this regards. How these peak can be resolved and separated. i am using pure methanol as mobile phase with flow rate 2 ml/min, uv detector at 292 nm, column kromasil 100 5 micron 150x4.6 mm. With thanx
Difficult to answer without more information:
What are the k' values of the two peaks?
What kind of efficiency (plate number) are you seeing?
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 26 guests
