Dionex AS autosampler moduleware
I need a pre-2.30 .fmw file to revive my AS autosampler. With the AS_2.30 moduleware, I get errors in CM6.8 such as "bad parameters" returned during a "wait" command. Can someone be kind enough to share one? The previous one was 2.20 and worked ok but since it wasnt broke, well, you know the rest...
Bad Param error means you’ve maxed out a variable count in the front screen panel. If I remember, I think it’s number of injections, reset to zero using the keypad and it will work again. No FW needed
Hi, did you ever get the firmware? We have the exact same problem as you and really need the firmware too! If you have a copy it would be great if you could email it to me at dj-hayes@hotmail.co.uk
