dual wavelength detection
Hi, can Agilent vwd be programmed to collect at two wavelengths or not?
(I know MWD and PDA can)
Tina
With Agilent VWD you can switch to a different wavelength using a time command, in the timetable. So if the peaks are separated, you could change the wavelength in between them.
You cannot measure two different wavelengths at the same time with VWD.
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 22 guests
