Peerless Basic C18 equivalent column help
I need evaluate/analyze using equivalent column of peerless basic c18. Could any of you please give your ideas of what is the equivalent column of this? i can get columns from US market, so please suggest the column that available in US.
method:
pH3.0 sodium dihydrogen phosphate buffer and acetonitrile
gradient 10% organic to 50% organic in 20 min. flow 1ml and wavelength 220nm.
I really need to know what the equivalent column for this peerless basic. Please let me know any of your ideas.
You can use a Symmetry C18 column with this mobile phase...
What are you trying to do?
I am waiting on this column to arrive from India but i know it will take too long. In the mean time i am planning to run this method on Gemini C18 hopefully this column is equivalent enough. I will also try as per your idea on Symmetry C18.
any other ideas or input would be helpful.
I suggest looking at the link below and see if you see any of the compounds of interest:
http://www.imtaktusa.com/library/technical_information/
I have looked at the compounds and i could not find what i need. This compound is a week base.
This column is manufactured by Chromatopak Analytical in Mumbai India www.chromatopak.com and they can ship, direct to the USA in 3-4 day delivery with most couriers. If you use the original column then there is no need to look for equivilents/alternatives and the issues that going through the cycle can entail. I have sourced these columns for people in the UK before with no problem.
Any separation can always be improved upon given time
In total there are 23 users online :: 2 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 21 guests
