serve connection trouble galaxie workstation
Hi
I've a varian CP 3380 GC working with the software Galaxie Workstation, today when I tried to open the software a trouble message was send.
The message said: ‘Server connection: Unable to connect: EnxPooledTransportException during logon procedure:
NexusDB: <unnamed TnxWinsock Transport instance>: Cannot locate or connect to network server
Looking informatio found that a possible solution is to run a tool called: 'fixGalaxieServerSettings.exe’ but I can find it.
Someone can help me?
Thank you
Hi, did you get a copy of the tool and have you fixed the issue?
Hi Bob,
We are looking at old message strings related to issues with HPLC Varian Galaxie software issue.
I saw that you had a posted a solution to this problem that we are having while logon and shows "server connection unable to connect enxpooled transportexception during logon procedure at 142E830: NexusDB: <unnamed TnxWinsockTransportinstance>: cannot locate or connect to network server. [$2C0E/11278]" error.
So, If you have this file "fixGalaxieServerSettings.exe", please send us at madankumar.arumugam@unmc.edu. If
you don't have the file, any insights on how to get it Or send us the solution to solve this issue.
Your help would be greatly appreciated.
Users browsing this forum: Ahrefs [Bot] and 2 guests
