impurities and rrf
Posted: Sat Jun 13, 2009 11:53 am
Hi, I have another RRF question.
I have to validate a method for an impurity. The active is generally analysed at a different wavelength to the impurity, however, it can be seen at the same wavelength as impurity, to a much lesser extent.
In order to get a reasonable LOQ for the impurity in question I have increased the on column concentration for the sample solution compared to the previous method.
The active working standard concentration is 1% of the working sample solution concentration
I have to validate this method
I need to determine RRF as part of the validation. I planned to run active and impurity from LOQ-5 % of working sample solution concentration. and divide slopes
However, I was told that you can determine RRF using linearity plot and working standard at 100 % level. , and then another analyst determines RRF using impurity solution at 0.5 %. (specification limit)
Can anyone shed light on this, as I am not familiar with this approach.
MartinaMarie.
MartinaMarie.
