pyrophosphoric acid
am trying to find some pyrophosphoric acid (>95%) from a supplier other than Riedel-de Haen. CAS #: 2466-09-3
the reason for this is that the "de-Haen" material (500 g qty) comes to us in "blocks" in the bottom of the plastic bottle and it is very painful to work with.
tnx
s
mtnshawn,
I'm not aware of other sources of the acid but you have two options to get around this problem: melt the acid (it's supposed to melt around 61°C) or use the sodium salt as this is available as a fine powder from several sources including Aldrich and Fluka.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 5 guests
