7890B Agilent NO Peaks
Posted: Mon Nov 02, 2020 3:35 pm
Hi All, I am having a heck of a time troubleshooting my problem. My 7890B is not registering any peaks (except for the ignition peak). My column is a DB-WAX 530. What I have tried:
Replace Septum, Inlet filter, entire Inlet bracket assembly, Jet, and column.
I have baked the column, I have rinsed the column, I have recut and reinstalled the column.
I have manually injected sample, I have cleaned the syringe, I have confirmed it is drawing sample.
I have confirmed that gas there is no plug in the column, the gas is getting through beautifully.
I get baseline changes at different temperatures and there is a detection upon ignition, so it should not be the detector.
It ignites easily without issue.
I have checked all the lines for leaks.
I am at a complete loss as to what else it can be.
Help?
Help?
