application for Polysorbate 20
9 posts Page 1 of 1
want to quantify poly20 with non-ELSD method
anybody have a solution for same
As part of a matrix (i.e. product)?
10% or 10ppm? What matrix?
5 ppm
yes as a part of matrix with 5 ppm conc.
A nice application you can find under: http://www.chem.agilent.com/Library/app ... 8311EN.pdf
I'm sure from other manufacturers you will find also some application notes on Tween 20.
Good luck
5 ppm
Good luck
thanks dear
bur its elsd method, i have tried and its not suitable for low concentration approx 5 ppm.
I would like to analyze polysorbate 20 at a concentration of 0.05 mg/ml, or slightly lower, in a solution that contains protein, 10 mg/ml. If possible, I would like to use a simple method, including hydrolysis of PS20 by KOH followed by RPC analysis of the released lauric acid and quantification by using UV absorbance at 195-200 nm.
Is this possible?
Have you seen published methods that describes this? References?
I suppose that alternatives are including fluorescence detection after labelling of the released fatty acid? Do you have references to useful methods?
I am grateful for your input.
Best regards,
Goran Karlsson, PhD
Xbrane Biopharma
Sweden
9 posts Page 1 of 1
In total there are 23 users online :: 2 registered, 0 hidden and 21 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 21 guests
