Method and solvent for low weight acids and alcohol
Posted: Wed Jun 24, 2009 1:07 am
Hi folks,
I need to analyse a mixture of several low molecular weight compounds including acetone, isopropyl alcohol, butyric acid and mercaptoethanol.
(you can imagine it doesn't smell great). I'm using a 30m 0.25x0.25 wax column. Will it be possible to separate such a mixture with this column?
What would be an appropriate solvent? I was thinking DMSO. I'm using GC FID with Hydrogen carrier gas 45cm/s.
Rick
Rick
