Nucleotide separation columns available commercially?
For my experiments i need to separate all the nucleotide and hyperphosphorylated nucleosides from a cell extract.. Basically it would be nice if i can find a column which can bind these molecules and then can be eluted out later.. Is there a commercial chromatographic column which solves this purpose??
Look for the Oligonucleotide Separation Technology (OST) columns at the Waters website. You will find plenty of application notes, or you can get a brief overview in the column catalogue 720002784en.
Is it true that OST columns are just your normal BEH columns with a blue label ?
Alternativelly, you can use a CE method. There is quite a lot of papers dealing with analysis of intracellular nucleotides by CE. I found this one handy :
http://www.ncbi.nlm.nih.gov/pubmed/1720 ... d_RVDocSum
In total there are 26 users online :: 1 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 25 guests
