Implementing RF Values vs ''impurity vs impurity''
Can someone outline how this works?
This works in the same way as (relative) RF ''impurity vs API''.
In both cases, the response factor RF1 = Signal1/Conc1 of one compound (say, compound 1 (= impurity 1)) is determined (when the analytical method is developed) and compared to the response factor RF2 of another compound (say, compound 2 (= impurity 2 or API in the two considered cases, respectively) resulting in RRF = RF1/RF2 (or RRF = RF2/RF1).
This allows one to eliminate the need of using the reference material of compound 1 (since it may be expensive) in the routine application of the analytical method. Using only the reference material of compound 2 and knowing the previously established value of RRF allow one to determine the concentration of compound 1 in test samples.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 7 guests
