Peak width @1/2 height calculation in Empower software
Posted: Wed Jul 29, 2009 1:54 pm
Does anyone know how to use Empower software to calculate peak width at half height of a chromatographic peak? Please advise.
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
assuming you have bought the Sys suit pack...For Empower 2 (and, I think - build 1154 as well) -
It's built in. If all you need is to see it, right click on a table heading in "Review", select "Table Properties" and uncheck "Width @50%".
If you need to add this as a column in a report, it's under "Sys. Suit. Peak".
Did you enabled your system suitability option in the sys suit tab in your processing method?I did uncheck the "peak@50%" box (and other likes peak@10%, etc) and the column did appear. However, only the area, start and stop time, etc appeared but nothing under peak@50% (or others). Any idea please.
Ace, it works. Many thanks. BTW, do you have any software manuals for Empower software 'cos Waters does not provide any to us?Did you enabled your system suitability option in the sys suit tab in your processing method?I did uncheck the "peak@50%" box (and other likes peak@10%, etc) and the column did appear. However, only the area, start and stop time, etc appeared but nothing under peak@50% (or others). Any idea please.
Ace
