Normal phase LC
Dear all,
Wondering if I need to change the pump seal when I switch my Waters 600E pump from reverse phase LC operation to normal LC. Apparently there are heaps of different pump seals available but they look similar. Thanks for your suggestion.
Hubert
I would check with Waters. The standard seals are "general purpose" and can be used with a wide range of solvents, but there are some compatibility issues.
In total there are 20 users online :: 2 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: 0ct4n3, Semrush [Bot] and 18 guests
