Entrance Lens at zero voltage-5973
Posted: Mon Aug 10, 2009 9:55 pm
Has anyone come across an Entrance Lens voltage of zero upon autotune?
5973 MSD.
It's not a consistent thing but happens enough to question what the cause may be. 69 will be about half of normal abundance when this happens with 219 double it's normal abundance. You get 300 percent 219 relative to 69 at some times with this combination.
If I can remember correctly I believe I've tried another copy of atune with no change in results thinking it was software related.
Any ideas are appreciated. Faulty wire to the entrance lens pin? I have two machines that this happens to. They run the same analysis and take a lot maintenance. Faulty wire somewhere?
Thank you.
5973 MSD.
Thank you.
