Finnigan GCQ repair
Does anyone know if there are companies that still repair this type of GC/MS?
It is no longer supported by ThermoFinnigan or GenTech Scientific.
Thanks.
A local company named Terra Technologies in Louisville, KY used to work on these instruments. They are reliable but have a limited geographical area. However, they might be able to suggest alternatives. I used to run the GCQ systems myself before I retired. A lot of the basic hardware systems used in the GCQ are basically still in use with the newer models from Thermo such as the DSQ.
Thanks. I'll check into it.
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
