PPM N2 analysis in pure Krypton
8 posts Page 1 of 1
Dear sir,
I would like to know what would be the best columns and valve configuration to use for analysis of ppm N2 in pure Krypton.
I tried with a long Molecular Sieve 5A, but both peaks coelute together.
Thanks for your help.
You can see from the reference a capillary MS5A will not work for ppm analysis of N2 in Kr.
Call Supelco Tech Service and they can tell you how you can do the analysis with 3 feet of packed columns, a 12 inch and a 24 inch.
I don't work for Supelco but I did, and I told them how to do this analysis.
best wishes,
Rodney George
consultant
Hi Rodney,
Could you please let me know what would be your suggestion of columns and configuration. You gave me some good suggestions in the past that have worked.
I will contact Supelco after to order the necessary parts.
thank you
The configuration is a two column heart-cut with backflush.
The nitrogen elutes at about 1/4th the time of krypton, about 12 seconds at the beginning of the heart-cut, the cut being about 6 to 12 seconds in width, and then the backflush is operated.
You may be able to do a simple backflush to vent, but I suggest that you don't for best results. If it doesn't give you a high background with your detector, go ahead and do a simple backflush at about 30-35 seconds.
Other details you can discuss with Supelco Technical Service.
How does it feel to get $5000 worth of information for FREE ? :D
best wishes,
Rodney George
unpaid and unemployed consultant
Thats is a real GC guy!!!
As usual, a lot of accurate details!!! Good ;)
I'll get in contact with Supelco for the right columns.
Do you have a good contact name I could get in contact with in Supelco
thanks again
One more thing for you, Rodney.
Could it be possible to send to my email (dgagne@solutionld.com)your personnal information. Just in case I would need your support in future.
Let me know if it is possible.
many thanks
Dany
Dany,
Here is my email address and my home address is:
chromatographer1@aol.com
3501 SE Adams Drive
Blue Springs, Missouri USA 64014
816-600-8290 is my phone
best wishes,
Rodney George
consultant
8 posts Page 1 of 1
