Separation of D & L phenylephrin
how i can Analyze D & L phenylephrin in Reverse phase Chromatography without using Chiral Column on UV Detector. I Have the C-8 , C-18 , Cyano Column For The Analysis.
To separate D/L isomers, you either need chiral additives to the mobile phase or a chiral stationary phase.
The enterprise to do it with additives in the mobile phase is not trivial, and you will be better off taking a pre-cooked method from the literature or from a manufacturer of chiral stationary phases.
In total there are 18 users online :: 2 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 16 guests
