ESI of protected Arginine peptide
dear All
I have a peptide of which the only residues are Arginie (7 total ) and Glycine (2 total). The side chains of the Arginine (guanidine) was protected by pbf.
I need to do some modifications to this peptide and plan to use ESI to monitor the reaction progress. As the peptide is not dissolved in water. I am using DMF (dimethylforamide) as solvent.
When I tried to measure ESI, I diluted the peptide/DMF solution 10 times using water, and injected into ESI. However I could not see any expected peaks.
My question is: can I use ESI to detect this peptide ? As the side chains of the Arginine was protected by pbf, is the peptide ionizable under ESI condition? Does DMF do anything bad to the ESI?
Are you sure your protecting groups are not "ESI labile"?
Excuse me the stupid question but I'm not familiar with this chemistry.
Samuele Pedraglio
Developability Dept.
NiKem Research S.r.l.
Italy
Here is the structure of protected Arginine residue:
Please help!
In my opinion you shouldn't have any problem detecting your peptide.
Two questions:
1) are you doing an injection or a lc analysis?
2) What do you mean with "Expected peaks"? Are you talking about fragments or charge state?
Samuele Pedraglio
Italy
