After using TFA...
So I was asked to try a method involving 0.1% TFA on our LCMS for the first time. The analyte in question has heaps of sensitivity so the resulting ion suppression is fine. However I am reading of how it causes ongoing ion suppression in negative mode due to sticking around in the system even after it's no longer in use. I see that in some threads the degasser came up as a site of sticking.
I did make sure to at least swap out the column for one that we do not use for any routine work. TFA has not gone into our most usual column.
So, if I experience any such suppression in our next negative-ion method, is there anything specific I should be focusing on in cleaning? Are there particular solvents or reagents I can put through the HPLC and MS systems to get rid of TFA, or specific types of cleaning that will help? This is new territory for me.
Bump :)
I guess nobody has anything optimistic to say.
Users browsing this forum: Bing [Bot] and 15 guests
