Higer temperature, higher ionization efficiency?
Posted: Mon Oct 05, 2009 9:15 am
Hi all,
We have come across different vendors' LC-MS system. Some of them have 450oC in the spray chamber and others can reach up to 600oC.
For a general situation, is the ionization efficiency gets better if the temperature reach higher? (for both case of ESI and APCI)
And, what other factors (e.g. voltage, flow rate), can I alter to increase the ionization efficiency?
Secondly, in order to increase sensitivity (and S/N ratio), should I consider increasing EM voltage as the last resort? (Please correct me if I am wrong: I think increasing EM voltage will increase the signal but also increase the background noise, just like increasing ISO value in photography).
Thanks in advance!
Thanks in advance!
