FID /TCD compatibility for different brands
I want to know whether the Agilent detectors (FID,TCD,...) are compatible with other instruments from different brands like SCION. please advise
Only if you have a machine shop to make mounting adapters, and an electronics workshop to modify the control and signal boards.
The hardware side would probably be easier to cross over than the electronics. Every brand has their own operating system/firmware on the main boards and that makes most of the control systems incompatible cross platforms.
In total there are 16 users online :: 2 registered, 0 hidden and 14 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 14 guests
