Add menu in Chemstation B.04.02 installed with GC 7890A
Hi All
I need some help with Chemstation B.04.02 installed with GC 7890A.
I need to create a macro adding additional menu item in the Top Menu “Sequence”.
In this macro I need to add line to run the loaded method and start the analysis of the loaded sample.
Thanks in advance.
HAMA
There is a section on menu commands on page 411 in the Agilent "Macro Programming Guide". Someone posted a link to the guide in Agilent's site recently but I can't find it right now.
Hi
Copy this to the command line (or into the user.mac):
MenuAdd "&Sequence|&Run...", "&Run Method (F5)", "RunMethod"
This starts a single inject.
BTW: you can press F5 anywhere...
Hope this helps: A
thanks for help, and sorry for dely
HAMA
In total there are 19 users online :: 1 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: Ahrefs [Bot] and 18 guests
