Output of analysed peaks in a data sheet with EZChromElite
Hello everybody,
I found this forum yesterday and now your one of my last chances to find a solvation to my problem with EZChromElite.
When I integrate the peaks of my chromatogramm with the parameters for threshold and width set by myself, the software does great work. But my problem is, that I don`t need the output for peak area, retention time, etc. in the chromatogramm itself but in an output file. I've already found this "Costum report" - window but when I try to modify it with the editor in the "method" task list or get data from the chromatogramm exported to this report, it doesn't work.
Does anybody know what I can do?
I have not much time left in the lab, so it would be great if you could give me fast advice!
Thanks a lot!
Hi, you can use the export functionalities in the method advanced settings.
Thanks a lot for your answer,
I found the option you are talking about and it was a great help. Now, I don't have to note all retention times and peak areas by hand. :)
