Disappearing posts
Posted: Tue Nov 03, 2009 5:50 pm
by Rob
Has anyone else had this problem or is it me?
I just spend ages typing in a reply to a post and when I pressed submit it disappeared into the ether never to be seen again. Very frustrating and this happened to me before. I thought it just took a while to appear but days later nothing.
Posted: Tue Nov 03, 2009 6:13 pm
by grzesiek
Haven't had this problem so far, maybe some problems with your connection?
Posted: Tue Nov 03, 2009 6:39 pm
by HW Mueller
Recently, there were some very slow reactions, even with the statement coming that the page can not be found, or something like that. The posts were accepted anyway. Nevertheless, I have started to copy some of the longer contributions. . . . .
Posted: Tue Nov 03, 2009 6:44 pm
by Rob
Maybe it was because I didn't "preview" the message and just went directly to "submit". this will test that.
Posted: Tue Nov 03, 2009 6:45 pm
by Rob
No. that worked.
Posted: Tue Nov 03, 2009 6:47 pm
by Rob
Maybe it was the length of the message. I will follow your lead, HW, and use CTRL-C before I submit.
Posted: Tue Nov 03, 2009 11:57 pm
by Consumer Products Guy
Like HB, I copy my message into Word if it's going to be more than just a few sentences. Occasionally it just takes a long time and "times out" so that way I can just copy the response back in and submit later. I'm not very good at computers, and it doesn't seem to matter whether I go directly to Submit or Preview; some days you're the bug, and some days you're the windshield.....
Posted: Wed Nov 04, 2009 4:55 am
by tom jupille
I've had the problem occasionally since we moved to the new ISP late last year, but it's always been when logged in at home, and I have the same problem there with other sites. Unfortunately, it's hard to troubleshoot until you can establish a consistent failure mode. If the problem persists, e-mail me and I'll check into it further.
