two compounds eluting at same time
who to separate two compounds eluting at same time even if they dervatized??
Use a different column.
seems as though not you!
1.) Temperature Change
2.) Tweak Flow settings
3.) Different Column
What are the compounds you are trying to separate?
MS might be useful if they have different ions, just use SIM. However, keep in mind that (if the concentrations are high) some interferences are possible (suppression of ionization...), but even that can be solved by standard addition method.
Dejan Orcic
Asst. prof.
Department of Chemistry, Biochemistry and Environmental Protection
Faculty of Sciences, Novi Sad, Serbia
Asst. prof.
