Internal standard for HMMA
Hi
I measure 4-hydroxy-3-methoxymandelic acid (HMMA) by reverse phase HPLC with Electrochemical detection.
Currently I use 3-hydroxy-4-methoxymandelic acid (iso-HMMA) as an internal standard, but I can't find a supplier to replenish my stock.
Does anyone know of a supplier for this reagent, or can anyone suggest an alternate substance that I can use as an internal standard?
Craig
Craig,
you can search for your compound in: http://www.emolecules.com/
This database is free to use and will give you the names of suppliers to contact.
Good luck!
Kerri
In total there are 27 users online :: 2 registered, 0 hidden and 25 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 25 guests
