Pressure Builder on Argon for ICP-MS
Posted: Mon Aug 01, 2022 5:56 pm
How long should the Pressure Builder valve on a liquid argon tank be open before igniting the plasma?
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
Until the pressure is high enough for the instrument. If the instrument requires 80psi, then leave it open until it reaches that pressure. If it drops while running the instrument you will have to leave it open until you finish, then close the valve when it is not being used.How long should the Pressure Builder valve on a liquid argon tank be open before igniting the plasma?
