Empower 2 Report Creation -All in One
Posted: Sun Dec 27, 2009 12:57 pm
I am trying to go from using separate reports (one for the calibration curve, a different one for controls, one for samples, etc, etc) to putting everything in a single report that can be populated using a result set. I have used the correct functions for "label" and "label reference" and have had a lot of success getting everything in to one report using table data filters.
However, i am having some formatting problems. The empower help menus are not incredibly useful and I can not find any articles pertaining to these problems exactly. So here they are, hopefully someone has the answers and maybe others can benefit.
1) The portion of the report for the calibration curve plot and points table lists all of peaks integrated even though I am only calibrating for one peak in particular. I get the error message "Calibration Plot group for xxx contains no data" for every secondary component and a similar error for the calibration points table. This takes up about half a page and is not pretty.
2) I would like to create summary tables that contain information about multiple peaks in an injection. I might need to report the concentration of one peak, the purity of a second, and then the concentration of the third peak for instance. If I do not divide this in to three separate tables I will get a 3 lines for each injection, each line only having one of the columns filled out.
3) I need to set up my reports to handle n number of samples. If i set the tables to U* it will include all the injections from all samples in the same table. Is there a way to have empower create additional tables as needed by how far the U01, U02,.... labels go in the sample set? The only other way I can see to do it is to make a different table for each unknown. U01* U02* and so on an so forth. This would be cumbersome and still not able to handle infinite numbers of samples. Also, I have 3-4 tables for each sample as is...See problem 2
Leaving the data in 7-8 separate reports is not an option. I have spoken to people who have taken the "Advanced Empower Class" through waters and still do not know the answers to these questions. Thanks in advance for your help.
