eluotropic strength coefficient of mobile phase??
Hi
What is eluotropic strength coefficient of mobile phase?? How does this affect retention and resolution??
Thanks a lot
I posted about elutropic strength only three days ago.
http://www.sepsci.com/chromforum/viewto ... 9218#43116
For its affect on resolution, consider the equation:
Effectively, increases in k greater than ~ 5 gives the least reward with respect to increasing resolution. In general the selectivity term is the strongest.
Hi
I went through your post..some question still remains…taking eluotropic strength of a mobile phase/solvent into consideration how will I select a solvent to be used in mobile phase, lets say I have choice between ACN, Iso-propanol, n-propanol, THF…??? And how this will affect my selectivity/resolution??
(I have read in some article, where they have used a mixture of ACN and n-propanol for better resolution and have stated that this was done taking eluotropic strength into consideration...so this got me thinking on how did they decide??...;will try to get the article…)
Well thanks a lot
The selectivity of a separation is a more complex issue than just the retention. I gave it a shot for RP separations in a recent publication in J. Sep. Sci., which I am willing to distribute to those interested. The easiest thing to state is that a manipulation of the mobile phase additive is at least as powerful (if not more powerful) than to change the stationary phase. A few crude and tentative rules can be constructed for different organic modifiers. There is an interaction between the basic type of stationary phase and the effect of the organic modifier.
Hi..could you please provide me with this article...thank you
stirring up an old topic...
Was going through one article which stated (and i qoute)....the high eluotropic nature of these solvents (i.e propanol,isopropanol or butanol) restricts the selectivity of chromatography separation.
kind of baffled me...because i though eluotropic strength could add on to the selectivity of chromatography separation (plz correct me if i am wrong..)
so please help me to clarify...
There are actually several articles on the subject.
1. U. D. Neue, "Stationary Phase Characerization and Method Development", J. Sep. Sci. 30 (2007) 1611-1627
2. U. D. Neue, A. Mendez, Selectivity in Reversed-Phase Separations: General Influence of Solvent Type and Mobile Phase pH", J. Sep. Sci. 30 (2007) 949-963
3. U. D. Neue, J. E. O'Gara, A. Mendez, "Selectivity in Reversed-Phase Separations: Influence of the Stationary Phase", J. Chromatogr. A 1127 (2006) 161-174
In total there are 19 users online :: 3 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 16 guests
