Chemstation Level ID "CU"
Could someone enlighten me on the use of the Chemstation calibration level ID "CU". Cutoff.
I've always used a numeral for level designation in the calibration table.
This is for drug mode, drug analysis.
Thanks very much.
The CU level ID can be used to identify a cutoff level. If you change the numerical level ID to CU, the cutoff level and concentration will printout on all drug reports.
Okay thanks very much.
Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
