Shimadzu NIST17 conversion to regular NIST format
Hi fellow Chromatographers!
I am trying to convert the NIST17 Library from Shimadzu (.lib / .add / .nam /.str)
into the regular NIST format to use the library in OpenChrom.
I am referring to this post from 2014:
https://chromforum.org/viewtopic.php?f= ... st#p117078
I tried loading the .lib file into the Library Manager of Xcalibur 4.5 to convert into NIST. The response was 'ERROR - Unable to open the Finnigan library'
Any help or tipps would be highly appreciated :)
Contact Lablicate if you are willing to share test data, so the file converter can be improved.
Thanks for your answer! What do you mean by sharing test data? :)
You can provide a file that can't be read, which will be kept private but used to improve the converters.
