Custom library in Enhanced Chemstation and MassHunter
I have a custom library for GCMS put together in Enhanced Chemstation. This software makes a .L file. When I open it in my new MassHunter Library Editor I can only view the .L file NOT EDIT. Quite frustrating as I would like to add the .mol files and spectrum to it through MH Library Editor. Is there a conversion from .L to the .XML that the Library Editor uses?
Thanks for all responses.
install Masshunter Data Analysis. You can add item to library without converting the *.L to *.mslibrary.
