Autosystem XL GasChromatograph Autosampler elevator not init
I have a problem with the autosampler of our GC which displays the following error "elevator not init".
Can someone help me to solve this problem.
I have already checked the limit switches, and everything seems normal.
Thanks for your help
Is it possibly related to the exhaust door on the oven (left side panel) I think the exhaust door on the 690 threw a similar error when the limit switch was bad.
have a working one here, if you need help to check voltages or switches, let me know
and if you already solved the problem, it would be nice if you report the solution here
