Chemstation Level ID "CU"
Could someone enlighten me on the use of the Chemstation calibration level ID "CU". Cutoff.
I've always used a numeral for level designation in the calibration table.
This is for drug mode, drug analysis.
Thanks very much.
The CU level ID can be used to identify a cutoff level. If you change the numerical level ID to CU, the cutoff level and concentration will printout on all drug reports.
Okay thanks very much.
In total there are 35 users online :: 1 registered, 0 hidden and 34 guests (based on users active over the past 5 minutes)
Users browsing this forum: Amazon [Bot] and 34 guests
