Guard column compatibility
Discussions about gel permeation chromatography / gel filtration chromatography / size exclusion chromatography
I would appreciate your input on this:
I need to know how to identify a compatible guard-column with a column. Any recommendations?
In specific for a SEC column 30cmx7.8mm which pre-column would be compatible: a 6.0x40mm or a 7.5cmx7.5mm (or both?)
Thank you in advance 8)
A single guard is prefered.
Suppliers generally advice the same diameter, but in my case, narrower works without problem.
I would rather say that the key point is to have the same gel in !
