% Relative percentage difference
Hello!
Which is generally the acceptable % RPD between two measurements of the same sample? Can it be greater between low level results?
thank you in advance
The general acceptance limit does not exist. The limit depends on your task.
Usually it is the case.
In total there are 17 users online :: 2 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 15 guests
