% Relative percentage difference
Hello!
Which is generally the acceptable % RPD between two measurements of the same sample? Can it be greater between low level results?
thank you in advance
The general acceptance limit does not exist. The limit depends on your task.
Usually it is the case.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 10 guests
