post column split to set up Sulfur SimDis application D7807
Hi, I know I could use a microfluidic splitter, but are there any other splitters I could (hopefully way less expensive) use to accomplish the split necessary for simultaneous Sulfur and SimDis detection? Thanks for any suggestions!
I don't know the requirements of D7807 but if someone asked me about this type of application, I'd say this y-splitter might do the trick. Just adjust the length/diameter of the tubing from the Y to the respective detectors to get the split ratio you want.
https://www.restek.com/p/20277
Restek makes them in a few different dimensions to accommodate different column/tubing sizes.
I've used the press-fit ones with pretty good success. Just make sure the tubing cuts are flat. They usually seal up nicely.
thank you for the reply! Very kind of you!
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
