Jasco PU-1585 gradien system
How do I setup a gradient system with 2 PU-1585 pump without PC? Do I need a cable between the pumps?
Please help me?
If the PU-1585 pump is similar to the PU-1580 pump, then you can connect the LC-NET cable between them for communication. Go into program mode and set up the ID's for each pump, Pump #1 and Pump #2. Install an appropriately sized mixer for the application you plan on using (*mixer volume depends on: Column volume and flow rate used). This allows manual programming of methods (files) for gradient analysis.
