Options to Pickering derivatitization system
Hello
I wanted to know if there are other options for doing post column derivatization?
The only vendor I Know is Pickering.
Are there any other options in this type of equipment?
THks
Sometimes, it is enough to have a T-joint, a piece of capillary, and a pump for the reagent.
Hitachi, Sykam, and Shimadzu sell amino acid analyzers with post-column derivatization.
https://www.hitachi-hightech.com/file/u ... ochure.pdf
https://sykam.com/product/amino-acid-an ... -analyzer/
https://www.shimadzu.eu/products/liquid ... tures.html
You can find separate reaction modules by these vendors.
https://www.shimadzu.com/an/products/li ... index.html
https://www.selectscience.net/product/h ... mn-reactor
You can search for other manufacturers.
https://www.spectralabsci.com/equipment ... ondule-ii/
https://www.hplc-asi.com/post-column-reactor-modules/
