Troubleshooting High Backpressure in HPLC System
Posted: Thu Oct 17, 2024 10:35 am
Hello everyone,
I’m encountering an issue with my HPLC system and could really use some advice. Recently, I’ve been experiencing unusually high backpressure during my runs, and I’m not sure what’s causing it. The system had been running fine with a C18 column (4.6 x 150 mm, 5 µm particle size) and an acetonitrile/water gradient (60:40), but now the backpressure is significantly higher than normal, even with the same mobile phase.
Here’s what I’ve tried so far:
Thanks in advance for any insights!
- Flushing the system with isopropanol and water to clean out any blockages.
Replacing the guard column, thinking it might be clogged.
Checking the fittings and connections for any leaks or signs of wear.
