Empower 3 Summary By All Report
I'm processing a sample set with 10 injections and I can't seem to find a way to add system name to Summary By All Report report (I'm using this report because I want data for all injections in one PDF).
I located the system name field I want but I can't make it show only once per particular sample, instead it gets listed 10 times (and then sample info comes).
I'm sure there is a simple way of placing this field but I just can't seem to figure it out.
You can add the system name to an All Peaks table and it should show in that column. If you only want it shown once, then group the System Field with the All peaks table and composite order by SampleName ascending.
or add it to a "first page only" header...
DR
