No signals on Waters 2489 ELSD
Posted: Tue Feb 09, 2010 10:13 am
Hi friends,
Recently our neighbouring research group bought Waters LC system with 2424 UV detector and 2489 ELSD, running Hexane:IPA 95:5 as mobile phase.
They have no experience about ELSD. What they found is: when no column attached, there are peaks in UV and ELSD signals. When column attahced, even as short as 3cm guard column, signal from ELSD gone. Only UV signals appeared.
They tried to change nebulizer temp, drift tube temp, pressure but no improvement.
Any suggestion? or reason about this? Thanks a lot
