Reverse Phase HPLC of protein using neutral PH mobile phase
Posted: Mon Feb 22, 2010 1:50 am
Hi folks,
I am working on a protein adduct characterization project. The RP HPLC seems straight forward to isolate the protein of my interest after the protein was alkylated. However, I found out that the adduct is not stable under acidic condition. (The mobile phase I am using right now is Water/MeCN with 0.1% TFA.) If I replaced 0.1%TFA with 0.1 formic acid, most proteins was stuck on the column. Therefore I wonder if there is any neutral solvent system for this kind of work.
Thanks.
Thanks.
