Self packing of HPLC column
Dear Chromotographers,
I wonder if packing HPLC columns by myself makes sense. Rostech sells a pump kit for packing HPLC columns and several companies sell all kinds of HPLC silica types, normal and reversed phase. My questions are:
1. Can I pack the column as good as the commercial one?
Is packing HPLC column as easy as it is descirbed in the instruction? I have not packed HPLC column by myself before.
2. Does it make economical sense to pack the column by myself. I am in an academic position, so minimizing cost is a big concern for running my lab. The HPLC packing station costs about $7000. i have two HPLC systems (Agilent 1200) in my lab and do go through 5 to 6 columns a year.
Thanks for you help,
Yongsong
Dr. Yongsong Huang
Department of Geological Sciences
Brown University
Yes, but only with a tremendous expenditure of time and effort.
No. The details must be optimized for each type of packing, and must often be "tweaked" for each lot. In a past life I was involved with packing columns commercially. For each new lot of packing material, we packed a dozen test columns (2 each under 6 different time/pressure profiles) to get the conditions optimized.
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 12 guests
