pyrethroids uing TR-5 column??
Hi
I want to ID and quantify pyrethroids.
I have a TR-5 column in my TRACE DSQ GC-MS.
Is it possible? Any idea w.r.t temperature program?
SM
SM
Hi
This article might help you:
http://yakushi.pharm.or.jp/FULL_TEXT/126_10/pdf/991.pdf
Generally "type" -5 columns seems to work, mentioned in the above article and in others.
Pyrethroids run great on our DB and Rtx 5MS columns so you should be good. A number of the Pyrethroids take fairly high temperatures to elute, so you might want to start on the hotter side and ramp up to 300ish.
@krickos - looked at the article, thanks!!
@jh1 - will make note of that!!
SM
