HPLC analysis of menthol
is it possible to analyze menthol by HPLC without any derivatizzation? Is it also possible to separate the two isomers l-menthol and d-menthol?
Any suggest will be appreciate.
Thanks in advance.
We've only used GC here for menthol assay.
Most organic species can be detected by HPLC at low UV if the matrix contains no interfering species, and often times using refractive index detector.
Found a reference to a normal phase method here http://www.informaworld.com/smpp/conten ... 651&db=all
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
In total there are 21 users online :: 2 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 19 guests
