Dionex ASRS suppressor 2mm use with a 4mm column and more...
I have this 2mm supressor and I want to use a 4mm column. I assume the only difference between the two suppressors (2mm and 4mm) is the capacity of supression. The 2mm is capable up to 1mL/min according to its specs. My application needs just 1ml/min. Will I be ok using the 2mm suppressor? Any drawbacks you could think of? I would rather not buy a new suppressor...
Also any suggestions for good reliable and robust columns that have reasonable pricing for common anions and cations (non suppressed).
anyone that could hep on that?
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 22 guests
